ArcGIS Desktop support for WMTS files
733
10-15-2019 10:29 AM
ZarehDemirdjian
Hello,
I know that ArcGIS Server supports WMTS format.
However, when exporting the map from ArcMap to the server the WMTS format (x,y,z) capability is not supported.
Am i missing something?
Thanks
-Z-
jill_es
How are you exporting the map from ArcMap to ArcGIS Server?  Are you publishing a map or image service?  If you're publishing a cached map or image service, WMTS should be enabled by default.  This is explained further in our documentation here.
