ArcGIS Data Store Hosted Feature Layer stop responding
24191
20
03-11-2022 07:15 AM
AndreaV
Hi all,
I have a single server base deployment of ArcGIS Enterprise with a lot of Feature Layer (Hosted) Services.
After a while I notice that this services are no more responding, I get errors like:
"The layer, xxx, cannot be added to the map" in my Web Map Application
or the rest URL of the feature service s"/arcgis/rest/services/Hosted/xxx/FeatureServer" appear as a blank page.
In arcgis server log I found errors similar to:
"Unable to process request. Service Hosted/xxx/MapServer not found"
"Error getting service" for all request to FL Hosted.
I investigated through "describedatastore.bat" utility and all seems to be ok
Information for relational data store ds_vgnupexh
Backup location.....................E:\arcgisdatastore\backup\relational
Is backup folder shared.............false
Backup schedule.....................{"schedule-starttime":"00:00:00","schedule-frequency":"Every 0 DAYS"}
Days backup retained................7
Data store status...................Started
member machines.....................MyServer
Maximum connections.................150
Owning system URL...................https://MyServer/arcgis
Portal for ArcGIS URL...............https://MyServer.domain.it/portal
Number of connections...............0 connection(s) to managed database
Data Store mode.....................READWRITE
Is Point-in-time recovery enabled...No
Query optimizer enabled.............Yes
and I can validate the relational datastore through ArcGIS Server Manager -> Data Stores -> Validate.
How can I investigate and solve this problem?
thanks in advance
Andrea
jonathanharte
I've had similar issues .....   everything comes back up ok but cannot publish new hosted feature content...
The solution @https://community.esri.com/t5/arcgis-enterprise-questions/preferred-order-of-stopping-portal-arcgis-...    PaulDavidson1 response, works for me with one extra step .. when Portal is back up and settled - restart the Arcgis Server instance .. wait for 5 mins and it all starts publishing again....
hopefully I haven't confused things .. but this is my goto for restarting
