ArcGIS Data Store Date Directories and performance
1114
03-06-2023 12:40 AM
MarGIS
Hello, Everyone
I am in the middle of installing ArcGIS Enterprise that will support 3D applications based on Point Cloud data. My question is where to store ArcGIS data store tile cache (data directories)? Could I store it on (NAS storage) or I have to store it on local drive? given that the Point Cloud data will be (TBs) in size.
Thanks
Scott_Tansley
MVP Regular Contributor
Hi.  You can only use local disk.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/create-data-store.htm#:~:text=Keep...
You should also consider this advice:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/install-data-store.htm#:~:text=Esr...
Effectively you could use premium disk (performance) on your base deployment/hosting server, and for the tile cache host you could potentially use lower grade disk to save on budget without compromising performance elsewhere in the system.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
MarGIS
@Scott_Tansley  Thanks for this helpful information, I do appreciate your support
BillFox
MVP Notable Contributor
Do you have ArcGIS Image Server too? Image Hosting and Raster Analytics?
MarGIS
@BillFoxI have only Image Hosting server (Image server license). Is it a must to configure the Image sever with Image Hosting and Raster Analytics at the same time so that I publish scene layers from LAS files?
