ArcGIS Dashboard with Select by Location function
1380
03-26-2024 04:58 AM
CMcDonald
I wonder if it's possible to use the Select by Location functionality that is available in ArcGIS Pro?
What I would like to do is create a Dashboard which the user could first filter to the Zone required (red polygons) then use the Point data which contains properties to "select by location" for that Zone.  The properties/point data does not have a column with the Zone number otherwise I guess this would be possible?
I wish to calculate the number of Points within the Buffer Layer I have added to the map.
I hope by explanation and screengrabs are enough?
Thanks in advance.
