agssom.exe in v10.2 to Manage ArcGIS Server Services
4128
5
10-10-2013 10:50 AM
MichaelVolz
Esteemed Contributor
To All ArcGIS Server Users and Administrators:
Is there a version of agssom.exe that is available specifically for v10.2, as this is what I am using in v10.0 to manage services from scheduled tasks?
If this is not available, is there alternate software that can manage services through scheduled tasks?
StevenMoore1
I don't believe there is a 10.1/10.2 version of the AGSSOM utility, but there are command line utilities available:
http://resources.arcgis.com/en/help/main/10.1/index.html#//015400000626000000
You can start/stop services and manage caches with the utilities.
Hope this helps.
KevinHibma
It looks like the guys from Boston did recompile agssom for 10.1 and presumably 10.2.
I'm not 100% sure if agssom needs to compile against a particular version with the changes from 10.1/10.2 compared to 10.0.
Anyways, agssom and the ArcGIS Administration Toolkit can be found here:
http://www.arcgis.com/home/search.html?q=agssom&t=content
In short, both these samples build off the command line tools idea that Steve posted, but leveraging the API via .NET or Python.
MichaelVolz
Kevin:
Your link brings me to an ESRI website that shows no matches.  Can you check the link and resend if necessary?  Thanks.
KevinHibma
Make sure the box on the left side "show desktop content" has been checked
MichaelVolz
Thanks Kevin.  Your second link did the trick.
