AGOL or ArcGIS Portal- Consuming WFS/WMS from Geoserver
2713
02-28-2017 12:19 AM
ManojGarg
Hello All,
Can you please let me know AGOL or Portal can consume feature/map services which are not ESRI hosted for example geoserver WFS/WMS. If so then how? Or in order for AGOL/Portal, service should be hosted by them only.
Many Thanks
Manoj
DerekLaw
Esri Esteemed Contributor
Hi Manoj,
You can add both WFS and WMS services to view them in both the ArcGIS Online and Portal for ArcGIS map viewers.
Add layers—ArcGIS Online Help | ArcGIS
Hope this helps,
DerekLaw
Hi Manoj,
Hope this helps,
ManojGarg
Thanks Derek.
