Accessing HTML pop-up information inside Google Earth via ArcGIS for Server services
1443
09-15-2014 12:47 PM
JaromHlebasko
I'm not a Server or Google Earth expert by any means; however, I was able to successfully establish a KML file from the REST url provided by publishing a service through server. This service has feature access capabilities and I did enable the HTML pop-up tool in ArcMap for the particular layer I want information to show from before publishing; however, when I open up Google Earth and bring in the network link, I click on an asset to see the attributes and nothing happens. First and foremost, is this even a possibility and second, If it is possible, what am I doing wrong?
Thank you in advance!
MarkBockenhauer
Jarom,
ArcGIS Explorer Desktop will support your service and display the popup as authored in ArcMap via the service.  It is not the same as Google Earth, but similar.   ArcGIS Explorer | Download
Mark
