access relational datastore postgres database in arc catalog
2275
06-23-2021 01:27 AM
by Anonymous User
Not applicable
Hi All,
is there any possibility to access the data in relational datastore through arccatalog ? if yes does it shows spatial data or only tables ?as per the documentation esri says it does have tables in postgres relational datastore.
kindly suggest on this.
Scott_Tansley
MVP Regular Contributor
The ArcGIS Data Store is only supposed to be accessible via the REST interfaces (via the Hosting Server) and certainly if you want to 'support'.  The PostgreSQL database uses none-standard ports, and hidden credentials to dissuade you from doing so.
If you want to use the data in a desktop product (recommend Pro) then connect via the REST endpoint or extract the data as a copy (fGDB) and use it that way.  🙂
Scott
Scott Tansley
https://www.linkedin.com/in/scotttansley/
VictorTey
Accessing the postgres database directly is not recommended by Esri however if you are really determine to access the relational db,  I don't see what can stop you :).
Have you tried updating pg_hba.conf(back this up first) to trust all host? that way you can log in without requiring a password.
cjms
The steps below work for me with PgAdmin
  1. Remote into server with the Postgres Data Store
  2. Open command prompt
  3. CD your way into the C:\Program Files\ArcGIS\DataStore\tools folder
  4. Run "listmanageduser.bat"
  5. Write down the username, password, and database
  6. Run "allowconnection.bat <ip of your computer> <username from step 5>"
    • example: "C:\Program Files\ArcGIS\DataStore\tools>allowconnection.bat 12345 user"
    • This will alter the pg_hba.conf file. You can open it to see your changes
    • IP is the computer you are using, not the server that has the datastore
  7. Open PgAdmin --> register new connection
  8. Enter username, password, and database from step 5
  9. Enter host name of the server with the datastore installed
  10. Port is likely 9876
    • Run 'netstat -ano' and search for the PID corresponding with the PID of postgres.exe in Task Manger
  11. Save connection
Tables will be listed under the Schema --> username --> Tables
