A request was made for service 'SERVICE_NAME.MapServer' but it did not have adequate credentials.
4906
13
11-22-2021 12:42 PM
by Anonymous User
Not applicable
Our GIS team is currently maintaining an ArcGIS Enterprise setup (10.8.1) which allows map requests to be made by users. However, one of our key services is sometimes giving out the following error:
"A request was made for service 'SERVICE_NAME.MapServer' but it did not have adequate credentials."
Usually this works as intended - a user who is the part of a certain group can add data to this table. However, this only sometimes works (the credentials are accepted around 70% of the time). The credentials for these users are not being changed, so this makes me suspect that it is a network/server issue.
Has anyone had a situation similar to this? Other posts mentioned issues with setting ownership roles but that is not the case for us.
mapgix
@Anonymous User could you check if you have shared the map service to the group as well? sometimes if you have only shared the feature service you might get this error.
Hopefully that resolves your issue.
ValerieSquire
Hello- I am experiencing the same issue. Did you ever resolve this?
RedaAli
Hello
I am experiencing same issue
JoshuaMurphy
Long shot trying to revive this old thread, but am recently experiencing this error sporadically in our federated ArcGIS Enterprise Portal (10.9.1). Has anyone found a resolution?
PhilippeChesselVdG
We do have the same sporadic error in our federated ArcGIS Enterprise Portal (10.9.1).
WARNING : A request was made for service 'Utilities/Geometry.GeometryServer' but it did not have adequate credentials.
Is there any configuration related to this warning  ?
Error code 7331
RZT
We came across this same issue and found that going into Server Manager and setting the sharing there resolved our issue. Not sure how this became disconnected from the sharing set for the Portal item, but it did.
KasamaP
That's also solve my issue thanks
Ian_Ice
This resolved our issue! We just encountered this in our 11.3 environment (Base deployment, scaled out on 3 VM's). All items in portal (feature layer, web map, app) were shared to Everyone and a group, but no one could view the feature layer unless you were an admin. I'm very curious as to how these items became disconnected in a federated hosting environment. Thanks!
DiegoMeira
I'm having the same issue in the ArcGIS Enterprise 11.3.
In our case the problem is with the print service. When the map and layers are shared with "Everyone" there is no issue. However, when the same map is shared with "Organization" it returns the "it did not have adequate credentials." error, even if I'm logged in as the owner of the item.
I'm looking for a solution, other than sharing the item with Everyone.
