76 million rows...SDE st_geometry vs Oracle sdo_geometry...
4900
09-11-2013 04:33 AM
JohnLewis
Does anyone know of why the sde.st_geometry functions take so long to run?  I need convert 76 million lat/lon's to shape objects.
We're running on a Windows 2008 server using Oracle 11gR2 64bit with 64G ram and 24 core processors.
Following is the code I used to accomplish this and the results of both the SDE methods and the Oracle methods.
--Oracle sdo_geomtry�?�
create table sample_points (
RECORDID,
SHAPE) nologging as
  (select  /*+ NO_PARALLEL_INDEX(jl) */
   tab_row_id,
sdo_geometry(2001, null,
sdo_point_type(longitude, latitude, null)
null,null)
from jl_points_all jl);
Table created.
Elapsed: 00:01:24.29
--ESRI st_geometry�?�
   RECORDID,
   SHAPE) nologging as
           tab_row_id,
           sde.st_geometry (longitude, latitude, null, null,0)
--Still running after 11 hours �?? only 4% of the datablocks read from the source table.
Does anyone know of faster methods using the SDE functions?
Thanks in advance
John
NidhinKarthikeyan
Honored Contributor
John,
You can post the question on Geodatabse and ArcSDE.
VinceAngelo
Esri Esteemed Contributor
I regularly load 8 million row GeoNames tables in minutes using the 'asc2sde' utility,
and have no difficulty copying sde.ST_GEOMETRY tables one to another, so the issue
may be something in your environment, or something specifically to do with the
sde. ST_GEOMETRY constructor.  Have you tried using sde.ST_POINT, much like
the SDO_POINT you're using?
You may be introducing inefficiencies by not specifying a coordinate reference (best
practice is to *always* define a non-zero SRID), but a call to Tech Support is the
best way to find out exactly what is happening, and what can be done to make
it better.
- V
