I am using the ArcGIS library in Python.
I was able to create a WebMap with the command
<SPAN class="" style="color: #2b91af; border: 0px; font-weight: inherit; font-size: 13px;">WebMap</SPAN><SPAN class="" style="color: #303336; border: 0px; font-weight: inherit; font-size: 13px;"> </SPAN><SPAN class="" style="color: #303336; border: 0px; font-weight: inherit; font-size: 13px;">()</SPAN>
I added some Layers on it with the command
<SPAN class="" style="color: #303336; border: 0px; font-weight: inherit; font-size: 13px;">add_layer </SPAN><SPAN class="" style="color: #303336; border: 0px; font-weight: inherit; font-size: 13px;">()</SPAN>
I added property on Web Map
and saved my changes.
But I didn't have Extent (Zoom to layer) in my filtered Layers
I would like to get the extent of the filtered layer to pass the extent in the webmap, does anyone know any way?
Library - https://esri.github.io/arcgis-python-api/apidoc/html/index.html
Hi Vitor Ribeiro,
If you know the extent, you can call
.update(item_properties={'extent': extent})
https://esri.github.io/arcgis-python-api/apidoc/html/arcgis.gis.toc.html#item
You should be able to grab the extent from the layer object that is returned from a search:
Here's a sample code:
from arcgis.gis import GISgis = GIS("https://ABC.maps.arcgis.com", "USERNAME", "PASSWORD")search_result = gis.content.search('title:LayerOfInterest', item_type = 'Feature Service')
if len(search_result) > 0: layer = search_result[0] #assuming we want the first layer. print(layer.extent)
Attached is a screenshot of the code running on my AGOL with the results displayed in the output.
Hope that helps.
This form works, but returns something empty.
These steps I followed to child Web Map with my desired information. The biggest problem is zooming to the extent of Filtered Layers.
- I created WebMap ()
- Add 2 layers to wb
- I gave a definitionExpression on my layers (as shown in print)
- Set up webmap_item_properties with title
- snippet and tags
- I finally saved the Web Map
Unfortunately the extent of the Map is too far away, showing the entire globe of the basemap. I would like to know if it is possible to zoom the moment you filter in definitionExpression?
Here's a screenshot of my Jupyter Notebook
In the empty line was my sql, but I had personal information and could not publish, but it was working
@DerrickWong i'm calling the extent of the feature im interested, but when i publish the webmap the zoom is still at global level. How could i fix it?
Hi @Carlode_Stefano
How are you publishing the web map and where are you viewing it from?
If using the map widget from Jupyter Notebook, you can configure the desired zoom level via the attribute zoomlevel
If you are using Publish Item, you can specify the extent in the layerInfo object.
Alternatively, you can always open up the web map in Portal/AGOL and change the extent/zoom and save the changes manually.
Derrick
Signed in members can post, follow updates, and more. New here? Register a free account.
