Why does the Portal for ArcGIS license expired when the ArcGIS Enterprise license is perpetual?
2751
01-24-2019 11:29 AM
EmilyL
Hello GeoNet,
I had an error message on my Portal page saying that "The Portal for ArcGIS licenses may be expired."
It was expired when I checked the keycodes file at C:\Program Files\ESRI\License10.6\sysgen
But why would it have a expiration date when the license says perpetual under My Esri account?
The problem is fixed after putting a new authorization code at the Portal for ArcGIS Level 2.
Does it mean I need to re-generate the code and re-authorize it every year even though the ArcGIS Enterprise license says perpetual?
Thank you,
Emily
ElizabethOBrien
Hi Emily,
I believe the behavior your are seeing is outlined and explained at the resource link below:
https://support.esri.com/en/Technical-Article/000020991
Hope this helps!
HilaryCurtis
Hi Emily,
If you contact your Customer Service representative, they should be able to help out.
Hilary
EmilyL
Hi Hilary,
Thank you for your reply.  Yes, I called them and they were able to help me to generate a new code to put in. But I still don't understand why I need to do that and does it mean I'd need to do that every year?
Thanks again,
Emily
ElizabethOBrien
Hi Emily,
Hope this helps!
EmilyL
Thank you Elizabeth.
