When i log in to Portal in ArcGIS online assistant I can´t see my maps and webapps. Why?
2012
08-22-2017 10:49 PM
SanneMikkelsen
I can log into AGOL assistent using my credentials for our portal. That works fine, but when I try to search Portal for ArcGIS, there is a timer-thing running in  the upper right corner, but nothing happens. The same happens with "view My content" and "view my groups". Have tried it in IE and Chrome, same problem.
JayantaPoddar
What is the version of Portal for ArcGIS?
Bill Major: Maybe you could help.
Think Location
SanneMikkelsen
PaulDavidson1
The timer indicates the page is still loading. Did you give it enough time to finish? Wait for a time out message.
Did you log in using HTTPS? If not, try that.
No or slow response can be many reasons. Assistant is a cloud based SAS. Could be a hiccup there, could be your end. Make sure you have other internet access.
Try it again later in the day?
-Paul Davidson
SanneMikkelsen
Hi again.
Same problem later in the day. And I tried both http and https. Also same problem. Could it have something to do with the firewall?
