Want table of addresses within a boundry I draw/Sketch, Public Outreach
381
09-10-2025 09:58 AM
BradMitchell
I have a project I will be working on to create a mailing list to provide notice to property owners about some upcoming work in their area and to provide them a survey.
I have a feature layer that has all my addressing information. I would like to draw a polygon around all the addresses I would like to use and be able to export to a table for creating the address labels. I am having trouble selecting and formatting the correct tools to produce the desired effect.
Brian_McLeer
If you can add a custom widget there is a mailing label one here.
https://community.esri.com/t5/experience-builder-custom-widgets/mailing-labels-custom-widget/ta-p/16...
SteveCole
Honored Contributor
Have you seen this recent ESRI Blog post about the public notification instant app?..
D_Atkins
Just one more idea, if a Javascript Map is an option: adding an Export function to the Sketch and Select sample would be another approach.
 Select features by rectangle | Sample Code | ArcGIS Maps SDK for JavaScript 4.33 | Esri Developer
