Vector Tiles Many Duplicate Labels at High Zoom
2385
16
08-30-2023 10:19 AM
JCGuarneri
I have a long-standing issue with my vector tiles that I've been trying to resolve. The issue is that I design my label classes in Pro and get results that I like. However, in the published vector tiles, there are invariably high densities of repeating labels at high zoom levels (see examples below). I've gone through the suggestions in https://pro.arcgis.com/en/pro-app/latest/help/mapping/map-authoring/labeling-in-vector-tiles.htm and made adjustments accordingly, but I still see this issue. I suspect there's something simple I'm missing. Does anyone have a good suggestion?
I'm working in Enterprise 10.9.1, publishing from Pro 3.1.3, but this has been an issue for years.
Desired:
Actual:
ChrisWesson
@JCGuarneri I presume they meant converting feature labels or annotations to labelled point features.
Anyway, tricks listed above 🙂
ChrisWesson
@ChelseaRozek @JCGuarneri  Sorry none of this helped. We are fully aware that the labelling options in vector tiles are currently limited when compared to Maplex.
It is possible that what you are seeing is related to a bug we are currently investigating. It is also possible that small undissolved road segments and divided highways could be the cuplrit if you want to check for those.
Unfortunately I don't think there's anything else we can try.
JordanCarmona
ChrisWesson
@JordanCarmona @JCGuarneri @ChelseaRozek
I'd love to help finally get to the bottom of this. For us to better assist with unexpected repeating labels, can you please provide any sample data as a support case? It is hard to see what is going on without examing the tiles and changes between levels of detail.
I looked into the 2018 issue for clarification. The customer bug is that remove duplicates does not work, this is expected behavior. The reason we have an issue open is because while remove duplicates should not work, it does seem to be working with horizontal placements in current releases.
Fix labelling limitations is a far, far broader topic for discussion. At present vector tile specification simply does not allow us to control labelling in a similar way to Maplex.
ChelseaRozek
MVP Regular Contributor
Hi @ChrisWesson, you can view it just south of this parcel in our public app. I can open a support case to send a vtpk over, but is there a way we can escalate it to your team from the get-go? Which product should we call it as it's across Pro/Enterprise/AGO?
ChrisWesson
If you can open a support case with VTPK that would make it much easier, thanks.
Report it for the attention of the ArcGIS Pro, Multiscale Mapping team. That should help it get to us.
Thank you!
ChelseaRozek
@JordanCarmona It's been logged as a bug now, BUG-000179651
