Varying line size(thickness) based on attribute value?
4383
01-29-2014 11:35 PM
Syed_AzamGhouri
New Contributor III
Is it possible? how to do it? Thanks in advance.
TimWitt
Syed,
In your mxd go to the properties of your line feature. Then go to the symbology tab and on the left click on Quantities. Here you can either go with Graduated symbols or with Proportional Symbols. Either way make sure you specify the field, that tells the width, is used as your "Value" field.
Hope this helps!
Tim
TimWitt
Syed,
Hope this helps!
Tim
Syed_AzamGhouri
New Contributor III
Thank you Tim. It helps.
