updateFeatures returning Error: Operation without query criteria is not allowed.
1348
01-19-2022 01:46 PM
BanchanaPandey
We are trying to invoke updateFeatures rest api method from a java httprequest. The service is in an arcgis enterprise server.
portal url that will generate the token: https://organization.com/portal/sharing/rest/generateToken
feature service sevice url for updateFeatures: https://organizationservices.com/arcgis/rest/services/DRAFT_EDIT/FeatureServer/0/updateFeatures?
The token generation part is working fine.
The udpate part also returns a 200 message, but the data is not updated and we are seeing "Error: Operation without query criteria is not allowed."
Code Snippets  are posted below.
# Token Generation Part
      map.put(HTTPHandler.URL, https://organization.com/portal/sharing/rest/generateToken/)
      headers = HashMap()
      headers.put('Content-Type', 'application/x-www-form-urlencoded')
      map.put(HTTPHandler.HTTP_HEADERPROPS, headers)
     data = String('username=%s&password=%s&client=%s&referer=%s&expiration=%s&f=%s' % ("username", "password", 'referer', 'https://organizationservices.com/','json' ))
      responseBytes = handler.invoke(map, data)
      response = service.tojsonobject(String(responseBytes, 'UTF-8'))
      accessToken = response.get('token')
      # Got token
BASEURL = https://organizationservices.com/arcgis/rest/services/DRAFT_EDIT/FeatureServer/0/updateFeatures?
      url = URL(BASEURL)
      conn = url.openConnection()
      conn.setRequestMethod("POST")
      conn.setRequestProperty("Content-Type", "application/x-www-form-urlencoded")
      conn.setRequestProperty("Accept", "text/plain")
      conn.setDoOutput(True)
      conn.setDoInput(True);
      conn.setUseCaches(False);
      conn.connect()
      updateattr = "[{'attributes':{'OBJECTID':24,'PNUM': 'B-999-999','INSTALLEDDATE':1920}}]"
      params = "{'f': 'pjson','token': "
      params1 = accessToken + ",'features':" + updateattr +"}"
      fullparams = params+ params1
      postData = String.getBytes(fullparams, StandardCharsets.UTF_8)
      os.write(postData)
      os.flush()
      os.close();
