Unfederate ArcGIS Server site that no longer exists
8735
7
05-22-2017 11:03 AM
SebastianCabrera
Hello,
I´m trying to unfederate an ArcGIS Server site (geoevent) that no longer exists from my Portal (both 10.5), but the portaladmin interface doesn´t allow to remove de server if it doesn´t exist, it seems that the site must be online in order for the unfederation process to work. Is it right?
Thanks
JonathanQuinn
Esri Notable Contributor
You can remove it through the Sharing API:
https://<portal>.<domain>.com/<context>/sharing/rest/portals/0123456789ABCDEF/servers/<id>/unregiste...
This is only something that should be done if you know that the Server should no longer be federated to Portal.  You shouldn't unfederate as part of a troubleshooting process for your Portal and Server.  If you're troubleshooting something and considering unfederating, I suggest you reach out to Technical Support first.
JayantaPoddar
Did you try removing it from Portal website (My Organization > Edit Settings > Servers)?
Think Location
JonathanQuinn
SebastianCabrera
Thank you very much, this worked for me, since the server was decommissioned before being unfederated from Portal
rbae
Thank you Jonathan!
RobertDriessen2
What would I do if I have the reverse situation.  Portal no longer exists but ArcGIS server does exists and the server  is still federated with the non existing portal.
That is how do I unfederate a server when the portal no longer exists?
SebastianCabrera
You should go to the ArcGIS Server REST admin API, https://<yourarcgisserverfqdn>:6443/arcgis/admin/security/config and change the server role to standalone server, and authentication tier to GIS Server.
That should work
RobertDriessen2
Thank you Sebastian, that worked perfectly.
Much appreciated
