Unable to Load shared layers/services in map
259
04-05-2019 06:08 AM
JoelCrenshaw
After sharing a layer as a service we are unable to load it to a map. When using F12 is appears as though there is some sort of disconnect with the webadapters. The layers are hosted on https://xxx:6443/arcgis/rest/services but when using F12 while trying to load the layers it appears it is trying to look in https://xxx/portal/rest/services.
