I am facing an issue many people reported in the past with configuring web adaptor in IIS.
Current deployment: Enterprise 10.9.1, base deployment in a single VM (Azure), including both web adapators.
Upgraded in the same VM to 11.3.
The FQDN: https://vmname.subdomain2.subdomain1.domain.com
Alias: https://arcgis.subdomain1.domain.com
Internally (within the VM), the Portal and Server can be accessed via ports 7443 and 6443 respectively.
The credentials for Portaladmin and PSA (GIS server) works, which allows login to Portaladmin and Server Admin directories.
At 10.9.1 the Portal webadaptor was configured with portal name: https://arcgis.subdomain1.domain.com:7443 which set the portal to be accessed via: https://arcgis.subdomain1.domain.com/portal
But setting the same portal name in WA 11.3 configuration says
Error:
Unable to configure Portal for ArcGIS with the web adaptor. Please make sure that the Portal for ArcGIS machine is running and that the account specified has administrative privileges to the Portal.
Any suggestions to resolve this would be really appreciated. @JonathanQuinn any suggestions?
Just to also say that: apart from the web adaptor configuration aside, the upgrade worked fine: all three components are upgraded and can be accessed within the VM.
