Unable to Add Multiple Web Adapters Portal for ArcGIs 10.8.1
4596
10
02-10-2021 10:00 AM
SKW_UK
Hi All,
We are building out our GIS, and are having a few "issues" with the web adapter.
We have 2x Web Adapters behind a Load Balancer, which is the "Entry point" for our GIS.  This will be something like https://gis.com/portal
We also have 2x portals configured in an active/standby mode.  These are connected behind a load balancer, but only for admin purposes, URL would be https://gisportaladin.com:7443/arcgis
Both the WebContextURL and privatePortalURL properties have been set with the details above.
The issue we are encountering, is that registering one web adapter, de-registers the other! so we can only ever have one web adapter registered at a time.
Am i missing a really simple step?
Steve
Tags (3)
DEWright_CA
I had this exact scenario happen to me; what I had to do was on the 2nd server bind it to a different URL temporarily; when ran the Web-Adaptor Config process; then once the connection was made change the binding/url back.
Then I went into the PortalAdmin and did a Update on that Web-Adaptor record to reflect the URL.
