Symbol Display
992
11-02-2011 09:23 AM
RobCox
I have created a Symbol Line to indicate a Force Main Line.  When the segments are short, the arrow symbols on the line show up to the side.  Is there any way to remedy this problem?
SimonKettle
A quick fix is to convert to graphics and move the features.
This is only a temporary solution and if you need to edit it in the future you'd need a better fix.
You can also play around with the scale or line thickness and other features in the symbology tab...I have had a similar issue when drawing thrust fault lines where the thrusts symbols (a solid triangle on a line) detatch a look silly.
Bo_King
Bo_King
You may want to investigate the more robust Representation Rule symbology...
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//008t00000002000000.htm
