Rotating Symbols
1656
03-17-2014 09:46 AM
MichaelKohler1
Hi, I have some point symbols that I rotate because the data view has a specific rotation.  But when I rotate the symbols, they also rotate in the legend.  Is there a way to rotate the symbols on the map, but have a zero rotation in the legend?
Michael Kohler
JoshuaChisholm
Hello Michael,
When I set rotation for a symbol, it does not change the rotation in the legend. I set rotation by Layer Properties > Symbology tab > Advanced > Rotation. (I'm using 10.1)
MichaelKohler1
That worked, thanks.
RobertBorchert
Honored Contributor
You can also adjust a setting on the Legend to not change when symbols change.
However, the previous recommendation rotate based on attribute is the better option.  That is what I use as well.
JeffLegato1
I realize this is a pretty old post (2014!) but I found my way here for this issue and others probably will as well. In ArcGIS Pro 3.3.1 there is a setting in the Symbol tab of Symbology Properties where you can set the Angle alignment to be 'display' or 'map'. Set it to display on rotated map layouts.
