Rotate point symbol
120
07-23-2019 06:17 PM
ChrisRoberts2
Occasional Contributor II
I want to rotate a point symbol in a web map to point left or right based on the value from the Directions field (the values are left, right). This is for a Collector application to give the field operator a visual reference as to which side of the road the survey site is on.
I assume that this would need to be done  from an Arcade Expression, but I don't really know anything about Arcade and would even know where to start.
I would really appreciate any pointers that anyone might have.
Thanks in Advance
Chris
ChrisRoberts2
As usual, I post a question then work it out for myself 10 minutes later!  For those that are interested this is the expression used to rotate the symbol based on a value:
var rightrotation = 90;
var leftrotation = 270;
if ($feature.direction == "Right"){
return rightrotation;
    else{
        return leftrotation;
