reporting tool in insights for arcgis
2258
6
11-24-2017 04:32 AM
AliBarakat
Hello,
Is there an out of the box tool in Insights for ArcGIS?
if no, is it possible to create a custom tool and add it in insights?
Thank you
XanderBakker
Esri Esteemed Contributor
What kind of reporting functionality are you looking for? You can share your analysis results in a StoryMap, as explained here: Insights tip: Share your analysis using Story Maps | ArcGIS Blog
https://community.esri.com/groups/insights-for-arcgis?sr=search&searchId=af9871a3-6c9c-46d4-a0ff-2c8...
DouglasCochran
Yes, you can share a page or embed in a Story Map or web page.
Thanks.
KieranSmith2
This is helpful, but I was also looking for a way of exporting the results. I can see there is a Print option, from which I could create a PDF, but this is a standard web page print option rather than anything dedicated to saving as an export image.
Is this under consideration for a future release?
Thanks
DouglasCochran
Hello Kieran,  Yes, enhanced reporting/presentation is scheduled in 2018, which will provide even more capabilities.  Thanks for your feedback!
FirasBarham
Hello Douglas, is there any new tool has been added to the latest version of insights to export the results as a PDF.
Many Thanks
EdKnowles
G'day All
How does a 'normal' user print a shared Insights page?
It seems only the owner of the page can see the Print Page option?
The browser print option is no different?
Thanks
