Publishing a group subtype layer as a feature service failing?
600
10-29-2019 07:06 AM
KarenEllett
In Pro, I can add a group subtype layer. If I publish this to portal as a map image layer, it honors it and I have no issues.  If i publish as a feature service however, it publishes successfully - but that group subtype layer simply doesn't exist.  Layer id's will jump from 3 to 15 and skip over that group subtype layer.  If I try to publish as a webmap instead, it says it doesn't support that data type, error 24078. Is publishing feature services with group subtype layers simply not allowed, or am I missing something?
xyz_AL
Still no answer to this issue? Me too I've the same error.......
ArcGIS Pro 2.9.2
Thanks
