Print Widget - Custom Print Template - Custom text place holder
395
04-03-2026 05:01 AM
ChivoGIS
I’m working with a custom ArcGIS Enterprise printing template and would like to include text placeholders that the Print widget can recognize so users can type in their own text when generating a printout.
The issue I’m running into is that after publishing the layout and checking the Get Layout Templates Info output, my custom text elements do not appear in the JSON. Because of that, the Print widget does not detect or expose those text fields to the user.
Has anyone successfully configured custom text placeholders in a Pro layout so they are included in the Get Layout Templates Info response and become available in the Print widget? Is there a specific syntax, tag, or property required for text elements to be recognized?Printing template.pngPrinting template.png
Tags (1)
Laura
by MVP Regular Contributor
I have a title on my custom print service. Is that what you're referring to? Whatever the user types here (circled in the pic) will show up on the layout.
In Pro here is the dynamic text used:
CharliePoate
You need to re export your layout once you have added the custom text elements so that it is in the layouts folder used by the Export Web Map Tool and Get Layout Templates Info.
