Portal License File and Field Maps
2022
05-21-2021 10:37 AM
DavidColey
MVP Frequent Contributor
Hello - I've just generated my portal license file for 10.9 from our MyEsri page.  I am noticing that I am not seeing any value pairs for Field Maps in the json.  Should I be?
This is what shows in my file:
		"name": "Field Apps",
		"description": "Field Apps",
		"appBundleItemId": "fieldAppsAB",
		"apps": [{
			"id": "workforce",
			"entitlements": ["workforce"]
			"id": "collector",
			"entitlements": ["collector"]
			"id": "survey123",
			"entitlements": ["survey123"]
			"id": "QuickCapture",
			"entitlements": ["QuickCapture"]
@JonEmch , do  you have any knowledge on this one?
David
JonEmch
Can't say I have, I'll dig for a bit and see what I can find.
Keep on keeping on!
DavidColey
Ok thanks @JonEmch
JonEmch
Hey there David,
I just checked my test licenses, and found the config to be the same as yours. I don't believe we expect to see value pairs there.
Keep on keeping on!
DavidColey
Thanks @JonEmch  - yes I can confirm that no value pair is needed there and that the Portal upgrade from 10.8.1 to 10.9 has thus far been been successful, with the exception of the patch notification tool.  It is throwing a 'No URL' error.
Field Maps app works, Map Viewer Beta works. Web Styles updated.
