Portal for ArcGIS
3772
04-23-2015 02:19 AM
emmanuelshimabukuro
I would like to try Portal for ArcGIS, I have already a license for ArcGIS Online and ArcGIS server (10.1) but I can't find where I can download the Portal for ArcGIS setup.
All the installations tutorials I've seen refer directly to "Browse to the downloaded folder containing the Portal for ArcGIS setup..." and I can't find where this files are available.
Please, anyone know where I can find these files, or get access to a free trial ?
JayantaPoddar
Hi Emmanuel,
You could download it from your organizational account in https://my.esri.com/ , if available.
Else, I would suggest you to contact your local Esri Distributor for the setup of Portal for ArcGIS and also for its license (subscription based).
As far as I know, you also need to be under maintenance. Your local Esri distributor could brief you better.
Jay
Think Location
