Portal for ArcGIS 10.4 : How to configure secure Routing service
2473
05-09-2016 05:13 AM
AnjithaSenarath3
I need to add secure routing service under ArcGIS portal > Organization > Utility services> Routing services
How do we do that ? It keep poping up credentials to enter each time I am trying to use this service
JonathanQuinn
Esri Notable Contributor
Are you using built-in security for the routing service?  If so, you'll want to follow the instructions here​.  There's a section on if the service is not from a federated server and requires credentials.
