Portal for access rights n administration
1056
03-17-2023 12:22 PM
Ravichandran_M_Kaushika
Good afternoon.
We are in the process of moving our country wide ArcMap/ArcObjects based (10.6.1) application to ArcGIS Pro Add-in based application.  We would like to use Portal to perform administrative tasks such user access based on their counties or state-level privileges, security,  and other authentication procedures.
We have 2 main questions:
Q1. Can we create a group for each county in the US - 3000+ counties? Or Is there an upper limit for the number of groups in the Portal we can create?
We will be using the groups to perform the following tasks:
  • to streamline access to layers,
  • to provide ability to update features if needed, and
  • to perform other administrative activities as needed.
Q2. If there is an upper limit on the number of groups that can be created, Does Portal allow groups to create under a group?
We can create groups under each state to perform administrative activities as needed.
Thank you for your time.
Regards,
Ravi Kaushika.
IhabHassan
hi @Ravichandran_M_Kaushika
Esri doco doesn't mention if there is a maximum number of groups for you to create within an Enterprise.
I don't think there is an option for that.
Regards
Ihab
IhabHassan
Regards
Ihab
@IhabHassan ,
good morning.  Thank you for the pointed replies.
regards,
Ravi Kaushika.
