Portal Custom Privileges
1169
11-13-2016 05:18 AM
AlaaRasheed
Hello,
We have installed Portal for a client and the client ask us to develop a one page data entry form, the problem is they want single sign on with Active Directory and the admin page is the one that comes with Portal for ArcGIS.
My question can I add my own privileges then assign them to custom roles, the reason why I need to do so and cannot depend on custom roles only is that this data entry form will contain many parts that need to be changed based on user privileges.
Thanks
DerekLaw
Esri Esteemed Contributor
Hi Alaa,
> ... can I add my own privileges then assign them to custom roles
Portal for ArcGIS does not support the ability to add your own custom privileges to its system. You could submit your enhancement request on the ArcGIS Ideas space: ArcGIS Ideas
Hope this helps,
AlaaRasheed
Thank you for your reply,
I know that it is not supported, but is there a way to reverse engineer it ? I looked into the pgdb but I did not find a table for pre-defined privileges
Regards..
DerekLaw
Hi Alaa,
None to my knowledge.
Hope this helps,
