Portal Certificate Loss after machine restart
946
06-29-2018 07:00 AM
AhmadAwada1
Greetings,
I am facing an issue in arcgis enterprise 10.5.1 where i loose the portal imported certificate everytime I restart the machine.
I imported self-signed ssl certificate into portal (using portaladmin directory) successfully. After then I restart the portal server, the certificate is lost and the portal certificate reverts back to default portal certificate "portal". I noticed that the keystore named "portal.ks" located at "C:\Program Files\ArcGIS\Portal\etc\ssl" is replaced at every restart. Note that my windows is 2016 and i portal is configured in HA mode. This also happens in single mode (not HA)
I attached for the case below to show how the dates change for the portal.ks after restart and which means that it gets updated.
Please help!!!!!
Tags (1)
