Select the North arrow >> Properties >> Size and Position. Under the Anchor Point Graphic, choose the center point, and rotation should behave as you need.Best Regards,Jim
I expect that every element is tracked by a lower left and an upper right. When you rotate this rectangle, it changes the min / max values associated with the element.Regards,Jim
All,
I am using Data Driven Pages and it still "wanders" as the data frame rotates from page to page.
I have set the anchor point to the center but it still changes position.
Dan
I am also having the same problem (10.3.1) with data driven pages using a strip index where each page is a different data frame rotation. My north arrow symbol has a center anchor, but its position wanders all over the page instead of simply rotating around the center anchor point.
Suggestions?
I am also having a similar problem (10.8) with data driven pages where each page is a different data frame rotation. My north arrow symbol has a center anchor. It stays in the right place, but now it shrinks as it rotates! So every page it gets smaller.
Signed in members can post, follow updates, and more. New here? Register a free account.
