Map Viewer vs Map Viewer Classic Editing
1315
06-08-2022 03:44 PM
CarolynGao15
In Map Viewer Classic, you can configure a pop-up so that you can select certain fields to be seen and certain fields to be edited.
Is it possible to do this in Map Viewer? I want to be able to make one field editable and the rest of the fields are locked. I can't seem to find a function that lets me do this? Instead, I can enable/disable editing on the entire layer, but that isn't what I want.
An alternative I'd also be interested in is a way for another user to add comments to my polygons without altering anything else in the map.
Thanks!
e_mcc
Try doing this from the "Forms" section in Map Viewer. in forms you can add whatever fields you want, make them editable or not, specify other data editing formats/constraints...even u can set a calculated value.
Good luck!
E.
e_mcc
Good luck!
E.
CarolynGao15
Oh perfect, that works!
Thank you!
