How to use spatial analysis services in ArcGIS for Portal
5549
10-08-2014 05:48 AM
WhereMatters
When you have an AGOL for Org subscription, you have capabilities to perform spatial analysis in AGOL Map Viewer, for e.g. hotspots or geo-enrichment which produce a new feature service with results of the analysis.
How can we use the portal Map Viewer to perform the same analysis? When i add a layer to portal map viewer, i dont see the options to "Perform Analysis".
JacobBoyle
I've asked this several times of the staff i know at Esri involved with Server and Portal, and I've gotten the answer "it's coming", without a definitive date or release.  it's not in the Pre-release for 10.3, so i have a feeling it's a going to be a while before we see anything on this front.
WhereMatters
Thanks Jacob. Sad to know it didnt make it to pre-release for 10.3.
DerekLaw
Esri Esteemed Contributor
Hi Anand,
FYI, spatial analysis capabilities in the Portal map viewer will be part of the forthcoming Portal for ArcGIS 10.4 release.
Hope this helps,
