How to re-download Portal PRVC files?
3245
09-05-2018 02:49 AM
LR
I need to provide PRVC for both server and portal in the Enterprise Builder.
For Server, I can find the file here:
Manage Existing Provisioning Files > Pick Licence Type ArcGIS Server > Details > Download Provisioning File
Unfortunately, there's nothing for Portal there. There's only the usual EPC code under View Authorizations > Level 2 Named Users. There, I have "0 available of 1 total licenses", with an expiration date in 2019. Was the download option a one-time opportunity?
AmnoyAm
L R,
I'm afraid this is a limitation in MyEsri.  In your case, the Portal license was previously authorized.  You cannot provision a license if there is no license to provision from.  You will need to manually create the provisioning file.  Consider the following options:
   1.  Copy the existing provisioning file for your ArcGIS Server.  Open it in Note Pad or any other text editor.  The top section contains your personal information.  The bottom section contains your licensing information.  Remove the existing features for ArcGIS Server.  Instead provide the Portal ECP codes.  Here's an example:
// Features and authorization numbers
Portal Level 2=ECP123456789
Save the file with a .prvc extension.
   2.  Contact Technical Support.  An analyst can help you create the file you need.
DanPatterson_Retired
Provisioning files—ArcGIS Pro | ArcGIS Desktop
then there are a number of help topic links related to the type of user etc
Convert Named User licenses to Single Use—ArcGIS Pro | ArcGIS Desktop
Authorize and start ArcGIS Pro with a Single Use license—ArcGIS Pro | ArcGIS Desktop
If you aren't the admin, you will have to check with them, or contact esri
AmnoyAm
L R,
LR
Looks like this worked - I figured I'd need the Provision ID but the one already present in the server file was accepted too.
