How to change or convert string to date and hour format on Arcportal?
1543
11-19-2018 09:02 AM
ElisaA
I have a field that is a string but contains date and time.
I need to change this field type to a date and format such as MMddyyyy HHmmss so I can filter it in a Ops Dashboard. I've been told an arcade expression in the pop-up configuration might be able to do this? But I'm open to any solutions as well.
KevinDeege
Hi Elisa;
This thread provides one solution for this: Text to Date using Arcade Expressions
You may want to also check out the following blog, which contains some useful information on working with dates and times: Unwinding the Clock: Visualizing Time with Arcade
