how do you calculate rotation angle for data driven pages
17267
13
10-04-2011 09:52 AM
KarlKeough
I am using data driven pages with a pre-defined strip map grid. I would like to add the required rotation angle to an attribute field in my index layer. I can't find a way to make this work. I've tried the Calculate Grid Convergence Angle tool but this gives values that don't make sense (all values appear to be between -2 and 2, when the real rotation is far greater than that in most cases). I can make this work if I use the program to create the strip map grid, but not if I use an existing grid layer.
DavidWatkins
The Calculate Grid Convergence Angle tool calculates the angle for true north from the center of each polygon. If you use the Strip Map Index tool in the Data Driven Pages toolset to create your index features the angle will be populated automatically. If you already have an index feature layer you can use one of the COGO Report tools on the COGO toolbar to measure the angles. I believe the Angle Between Two Lines, or the Distance and Direction tool will give you the angle you need.
KimOllivier
Honored Contributor
It's much harder than that! I frequently want to adjust stripmap angles after they have been created and it is very difficult to calculate the angle of a polygon. COGO tools are no use because they only handle lines. You would have to split the polygons back to lines and then you would still not have a useful angle.
I wrote my own Python script and used math.tan2(y/x) to get bearings, that then had to be normalised.
You could use the new tool in 10.x Data Management>Features>Maximum Bounding Geometry
and set the option "Add geometry" which includes a nice field MBG_orientation suitable to use, but of course it is now in a new featureclass with all your nice attributes trashed, so you would have to make sure you group by SMAP_NUM , join back and recalculate. Still a bit less work that my Python script. But here it is anyway in case it helps you.
# UpdateAngle.py
# assumes rectangular polygons
# find bearing of longest side
# might have trouble with up
# 2 June 2011
# Kim Ollivier
import arcgisscripting
from math import *
import datetime
gp = arcgisscripting.create(9.3)
try:
    layer = sys.argv[1]
except:
    layer = "stripindex"
    ws = 'e:/teararoa/nz/current.gdb'
    gp.workspace = ws
if not gp.Exists(ws):
    print "ws",ws
    raise Exception
rotField = "smap_angle"
if  not gp.ListFields(layer,rotField):
    gp.AddField(layer,rotField,"FLOAT")
def calcbearing(dPt):
    calculate bearing of longest side
    # points
    pt1 = dPt[1]
    pt2 = dPt[2]
    pt3 = dPt[3]
    # lengths
    l1 = hypot(pt2[0] - pt1[0],pt2[1] - pt1[1])
    l2 = hypot(pt3[0] - pt2[0],pt3[1] - pt2[1])
    # bearings
    b1 = atan2(pt2[1] - pt1[1],pt2[0] - pt1[0])
    b2 = atan2(pt3[1] - pt2[1],pt3[0] - pt2[0])
    # print "test",round(l1),round(l2),degrees(b1),degrees(b2)
    # print dPt
    if l1 > l2 :
        degree = degrees(b1)
    else:
        degree = degrees(b2)
    bearing = 90.0 - degree
    if  bearing > 90:
        bearing = bearing - 180
    if  bearing < -90:
        bearing = bearing + 180
    return bearing
cur = gp.UpdateCursor(layer) ##,"ID = 1")
row = cur.next()
print
while row:
    feat = row.Shape
    for partNum in range(feat.partCount) :
        part = feat.getPart(partNum)
        dPt = {}
        n = 0
        for pt in iter(lambda: part.next(),None): # stops at null pt
            n+=1
            dPt = (pt.X,pt.Y)
    rotation = calcbearing(dPt)
    row.setValue(rotField,rotation)
    row.setValue("LastUpdate",datetime.datetime.now())
    # print row.objectid,row.id,row.island,rotation #,dPt
    cur.updateRow(row)
    row = cur.next()
del row,cur
Next the challenge will be to write something that will rotate the feature from the attribute. Numpy will be useful here.
Randy_A_Stapleton
Has anyone found a Simple solution to this? I am experiencing the same problem
DarrenWiens2
I believe you will still have to rely on a custom python script, although using arcpy geometry objects will likely shorten Kim's script considerably. I'll try to follow up on this.
DarrenWiens2
Here is a 10.1 script you can use to calculate the data driven page rotation angle into a field called calcAngle, for an index feature class of rectangles.
>>> import math
... with arcpy.da.UpdateCursor("RECTANGLE_INDEX_FEATURE CLASS",["SHAPE@","calcAngle"]) as cursor:
...    for row in cursor:
...        points = []
...        for part in row[0]:
...            for pnt in part:
...                points.append(pnt)
...        lines = []
...        for i in range(1,3):
...            lines.append(arcpy.Polyline(arcpy.Array([points,points[i-1]])))
...        if lines[0].length > lines[1].length:
...            firstShort = 0
...        else:
...            firstShort = 1
...        dx = points[firstShort].X - points[firstShort+1].X
...        dy = points[firstShort].Y - points[firstShort+1].Y
...        ang = math.degrees(math.atan(dy/dx))
...        row[1] = 360-ang
...        cursor.updateRow(row)
RichardKennedy2
Hi Darren,
This looks exactly like what I need however I cannot get the code to work for me. I am trying this in 10.3. I get the error message :Runtime error
  File "<string>", line 6, in <module>
TypeError: 'float' object is not iterable
I changed the Feature class and field names to match my layer. ("Release_Grid",["Shape","calcAngle"]
Any suggestions?
DarrenWiens2
Make sure you use "SHAPE@", a special token for the actual geometry.
RichardKennedy2
Got it! Thank you!!
JackZHANG
Thanks for Darren's script which works perfectly. However I found it requires the 4 points of the polygon be created in a certain order, which might be all right for index polygons created via DDP tool, but in our case we often got the index polygons from other source like CAD design where how it was created not always guaranteed. So I modified Darren's code a bit to allow the calculation work on polygons created in any direction. cheers,
