How do I stop a service that is running in Portal?
1359
08-06-2021 12:31 PM
JoseSanchez
Occasional Contributor III
Hello,
I published a web map layer from ArcGIS pro to Portal, but now I need to  stop it.
Thanks
jcarlson
MVP Esteemed Contributor
It may depend on the kind of service it is, but generally you can do that from ArcGIS Server Manager, typically found at your-org-url/server/manager
- Josh Carlson
Kendall County GIS
Yanlin_Li
New Contributor II
You can also stop services on ArcGIS Server Administrator Directory page
"FQDN/ name of your web adaptor/admin"
Choose the services you want, and click on them, and scroll down "stop"
JoseSanchez
I am not administrator of the Portal.  Is there a way to log in as a publisher like in ArcMap and stop/restart a service?
I need to stop a portal item, a feature layer.
The service  is a feature layer pointing to a feature class.
Yanlin_Li
New Contributor II
Hello Jose, apologized for the late reply, you can request a login from the administrator for ArcGIS Server Manager, https://enterprise.arcgis.com/en/server/latest/administer/linux/managing-users-in-manager.htm
You can just delete and republish the feature layer, as a workaround.
