We have a collaboration set up between our 10.6.1 portal and ArcGIS Online for which I want to delete a workspace entirely. I've deleted the workspace from the ArcGIS Online (host) and have left the workspace in the portal (guest) but there isn't a workspace deletion option in portal. The only action available from the cog is the join the workspace.
Could this be what "Remove Portal Group Link" in the portal directory is for (see attached)? I appreciate any help.
Hi Gregory, only the host can delete the workspace, and guests can join/leave. You should see the workspace removed on the guest automatically after deleting it from the host side (sometimes it takes a minute remove once you delete it). Are you still seeing the workspace in the UI and/or in REST even after deleting it from the host side?
Thanks, Hilary. It took some time (maybe a sync cycle?) for all of the collaboration components to disappear, but they're gone.
