flow symbol
5784
13
10-21-2013 01:00 PM
MikeHenson
can someone tell me how to draw the attached symbol. I am using for sewer line to flow the direction that I drew it. Thanks
NidhinKarthikeyan
Honored Contributor
Will you be able to upload the Feature class here
BenLeslie1
Is it possible to upload a geodatabase to the forum - I can't see how to do it?
Anyway I'm just testing the procedure so there is no proper data but these are the steps I have done:
1.  Draw a line
2.  Use Construct points to place points along the line.
3.  Set up a Representation on the line feature that follows the direction of the line.
4.  Set up a Representation on the point feature.
5.  Use Align Marker to Stoke or Fill so the representation on the point feature also follows the direction of the line (or that is the idea anyway).
What I ultimately want to do is:
a) Draw a line.
b) Add points along the line.
c) Rotate the points so they follow the line.
d) Copy the rotation value to a feature attribute so it can be read in another program.
NidhinKarthikeyan
Honored Contributor
You can find it under "Additional Options" - "Attachments" - "Manage Attachments".
BenLeslie1
Ah I see, I have to zip it.
