Federating Windows ArcGIS Server with Linux Portal
1010
04-29-2024 11:31 AM
BillShoop
Hey all!
Wanted to double check that federating an ArcGIS Server 11.1 installed on a Windows Server machine to a Portal 11.1 installed on a Linux machine is supported.
Thanks!
Bill
ReeseFacendini
Esri Alum
That is not supported or recommended. Please make sure that the OS supporting an ArcGIS Enterprise deployment is consistent throughout all the servers involved.
ReeseFacendini
Esri Alum
BillShoop
Thank you @ReeseFacendini
berniejconnors
@BillShoop it will work but webgisdr, the utility to backup your portal content, will not work if ArcGIS Enterprise components are installed on servers with different OS.
Bernie.
