Failed to import data to the content directory correctly. Unable to unzip portal content.
207
09-30-2024 10:02 AM
ajohnson_wsb
Hey everyone,
Trying to run an Enterprise Upgrade from 10.9.1 to 11.3. We keep getting stuck on the post-upgrade process where Portal is failing on the "Upgrade portal content" step.
Checked the Portal logs and saw the failure was "Upgrade failed. Failed to import data to the content directory correctly. Unable to unzip portal content".
Using this support article confirmed that the Windows service account had full control of each Portal directory. We also deleted the Thumbs.db files within the Content directory.
This is a single machine deployment, with everything (excluding web adaptors) on one machine, so the High Available issue does not apply.
If anyone has any insight or suggestions please let me know. We are waiting to hear back from Esri Support.
ajohnson_wsb
For anyone seeing this in the future.
We figured out our issue in this case was the antivirus on the server blocking something with the upgrade.
ajohnson_wsb
