Error handling service request :0x80004005 - No Layer or Table was initialized. in '"esriCarto.GraphicFeatureServer"'
579
04-15-2025 09:49 AM
Marco_Foi
We added a Postgres 15.8 - PostGIS 3.4 Data Store to ArcGis Enterprise 11.2
The Data Store has NOT been extended with the Enterprise Geodatabase support.
We have a simple "PostGIS" table with POINT geometry.
Using third-part desktop tools, the direct connection to the service allows to explore and edit the data, both spatial and attributes.
Using ArcGIS Pro 3.4, adding a Database connection we can add the table to a Map and inspect the attributes of the features. Just we canno edit them.. ..but this is expected as we did not enable the Enterprise DB in the Data Store.
In out ArcGIS Portal we could "Sync Layers" and the table was spotted and added as both a Feature Layer and a Map Service.
The problem comes with these services. When we try to access them using the REST API  (like https://contoso.com/arcgisserver/rest/services/myportalfolder/mytable/FeatureServer) we get the quoted ERROR.
Whata are we missing?
