Error handling service (0x80004005) in User-managed data stores in ArcGIS Enterprise.
5990
6
02-08-2024 03:16 AM
FrancescPuigvert
In the company we have Portal version 11.2 installed on a compatible Windows Server that accesses a Federated ArcGIS Server 11.2.
A User-managed data store is configured in the Enterprise portal. [URL]  to Postgres 14.
See literal help: "Relational databases can contain an enterprise geodatabase, but they don't have to."
By doing the Sync Layers, I can see how the datastore discovers the database tables/layers. But, when going to Feature Service's Data tab, the answer is: "There was an error".
The Log file says: Error: Error handling service request :0x80004005 - No Layer or Table was initialized. in '"esriCarto.GraphicFeatureServer"' Code: 500
In ArcGIS Portal and ArcGIS Server version: 10.8.1 and Postgres 10, it worked correctly. However after upgrading to Postgres 14 and ArcGIS Portal and ArcGIS Server: 11.2 it stopped working properly.
Additional: If I publish through ArcGIS Pro a service with a connection to the same database, it works fine.
FrancescPuigvert
There is a possibility of a bug that is known as 000165042.
JonEmch
Hey there Frances! This seems like something technical support would be able to help out with. Are you able to log a case, then let me know what the case number is?
Keep on keeping on!
FrancescPuigvert
Thank you very much, Jon.
Esri Case #03544598 - Data Store: Error al visualizar los datos.
Best regards
FrancescPuigvert
Sean-Sweeney
Hi @FrancescPuigvert ,
Did this ever get resolved for you? Was that bug indeed the answer? I'm running into the same error.
FrancescPuigvert
Unfortunately, I never found a direct solution for that, @Sean-Sweeney . I decided it was better not to wait and ended up solving it a different way: I automated the publishing as Hosted Feature Service.
Sean-Sweeney
Thanks for the update @FrancescPuigvert. I may try that route myself.
