Editing Layer Properties - unable to access
1333
12
04-16-2026 10:56 AM
Labels (2)
emacdougall
Hi!
I am working in Enterprise Portal 11.5 and am having issues in my map viewer. When I go to my layer properties, the panel is blank and I am not able to open any options along the side (properties, styles, pop-ups, etc). Wondering if anyone else is facing this issue or if it could be related to any recent patches put out? Any help or insight would be very appreciated!!
Cheers
Laura
by MVP Regular Contributor
What kind of layer?
emacdougall
Hosted Feature layer
Laura
Have you looked at installing patches for 11.5? Cleared cache? Tried in Incognito tab? Are you in an admin role?
https://support.esri.com/en-us/patches-updates/2025/portal-for-arcgis-11-5-web-applications-patch?tr...
BlakeTerhune
It's easy to click on the layer when you don't mean to and "unselect" it, making the properties pane on the right become disabled. Ensure you left click on the layer in the Layers list so there's a blue bar on the left of it, indicating it is selected. Also, make sure you aren't selecting a group layer, those might have different properties available.
emacdougall
I am able to select the layer and the properties become momentarily visible, but once I click on anything else in that pane, it goes blank.
BlakeTerhune
Interesting. What web browser are you using? Is there another one you can try?
emacdougall
I'm using Microsoft Edge. I just tried Chrome and had no issues.
BlakeTerhune
To confirm, you're saying the layer properties pane works fine in Chrome but does not work in Edge?
emacdougall
Yes! I'm having no issues in Chrome, and when I re-open everything in Edge again I'm facing the same issues.
