Domain subtypes are not exported to portal
1602
11-06-2020 07:13 AM
CliveSwan
Greetings,
I have an odd problem.
I was able to export a Domain and associated subtypes to AGOL.
When I export the same layer to Portal.
I get the fields, but not the domain or subtypes. The import button, with append data is not present in Portal??
Am I really expected to manually type them??
Anyone come across this issue?
Clive
by Anonymous User
Not applicable
Did you ever find a solution to this?
AnthonyTomAnoba
I'm experiencing the same thing. The subtype and domain will not show in the web app and dashboard. In the pop-up only the code of the subtype and domain is shown. Hopefully this has a solution already. 😞
