What are you using to clip the data frame shape? Is it a feature class, specified extents, or something else? I used another feature class to clip and it does not have the background.
Weird, I believe I am doing the same thing but it looks to be working for me. I'm at 10.1...
What version including service packs are you at?
Does one of the layers in the data-frame have a transparency or a graphic inserted?Any layers that have a transparency enabled will cause that "white" background effect and also, exporting to a vector based format will cause the white background to show up.See: http://forums.arcgis.com/threads/21701-inserting-a-png-or-imageThe workaround was to export the map to a raster like a jpeg, png, tiff...I also found recently that if I used ArcMap's export to PDF (from File pulldown) it would show the white background.I had to "print" the map using a PDF printer driver like "Adobe PDF" which would print the layout to a pdf file and that did not show the white background.
I am having the same issue. Did you ever figure this out??
