Custom print layout for widget that uses map series to print multi-page report and honors element selection?
1340
05-03-2023 09:38 AM
AllisonMartin
Wondering if anyone knows if this workflow is possible.
I'd like to create a Map Series print layout in Pro and publish to Portal to be used via a print widget.
I'd also like the map series to be able to honor the selected items in the webmap and only print the pages for the selected features.
Essentially,  I'm looking for something that functions similar to reports generated by Survey123.
We are currently using portal version 10.9.1
Thank you!
JeffMoulds
Check out sample #6 here...it should be a good starting point https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/convertwebmaptoarcgisproject.htm
AllisonMartin
This definitely helps, Thank you!
